Vista privelages
CCRussell
Vista privelages
Post by CCRussell »
I had a project that installed a .NET program using Installaware 7. If I installed this program on Windows Vista as an admin, then switched to a standard user (with UAC enabled), I could run the program.
I updated this project to Installaware 8. If I install the same way, when I switch to a standard user to run my installed application I'm getting program failures due to failed permissions.
What can I do to get Installaware 8 to install my product properly?
