I found the serial number sample and I know how to make it work.
My question is though, how can I generate a serial using PHP on my server?
Serial Number Validation
That's hardly an InstallAware question.
I have created a project that combines 2 of the samples provided with the product. The Serial Validation and the Online User Authentication.
I took the Serial Validation and modified it to include the online check. On my website I have a script like this that validates if the information sent is valid (you need to modify it to your own needs).
Hope this helps.
Hope this helps.
$sql_host = ''; //add host information here (localhost, mysql.host.com, etc.)
$sql_un = ''; //add your user name here
$sql_pass = ''; //add your password here
$sql_db = ''; //add your database name here
$link = mysql_connect($sql_host, $sql_un , $sql_pass);
if (!$link)
die('Could not connect: ' . mysql_error());
else
$db_selected = mysql_select_db($sql_db , $link);
if (!$db_selected)
die ('Can\\'t use foo : ' . mysql_error());
else
if(get_magic_quotes_gpc())
$parm = stripslashes($_GET['parm']);
else
if (isset($parm) )
$query_string = sprintf("SELECT * FROM `table` WHERE parm='%s''", mysql_real_escape_string($parm, $link));
$result = mysql_query($query_string, $link);
if (!$result)
die('Invalid query: ' . mysql_error());
else
$row = mysql_fetch_row($result);
//print("<BR>".$result);
if ($row)
print("OK\\n");
else
print("INVALID SERIAL 1");
else
print("INVALID SERIAL 2");
Thank you very much for sharing this with the InstallAware community!
Users browsing this forum: No registered users and 35 guests
