Microsoft .NET (x64) Runtime
Aaron Young
Post by Aaron Young »
Does InstallAware have a runtime package that supports installing .NET Framework 2 through 3.5 SP1 (x64) ?
When I searched for the answer I found conflicting posts; this one which says No, it does not:
http://www.installaware.com/forum/viewt ... hlight=bit
And this one, which says there was an update that does:
Could you (InstallAware) please clarify; if you do not, do you intend to in an upcoming maintenance release? If so, when can we expect it?
Regards,
- Aaron.
We do not have 64 bit runtimes bundled with the product due to space considerations.
You can easily call the native Microsoft installer using Run Program or make your own 64 bit runtime per the steps outlined in the Extending the Application Runtimes View whitepaper.
