Hello all,
is it possible to check if the grapfic card supports OpenGL?
Hown can I check if the grafik card supports OpenGL
moppelstroppel
Hi moppelstroppel,
I would be extremely surprised if any installer product offered a function to find that out.
You will have to write a dll, that you can call from your installer script.
To write the dll you might start at : http://www.opengl.org/
Rgds
Richard
Rgds
Richard
http://www.pointline.com
http://www.paraeasy.ch
http://ulrichard.ch
http://ulrichard.ch
