A question before purchase InstallAware
jason
Postby jason » Mon Feb 02, 2009 7:56 pm
Hi, currently i am a user of InstallSheild and searching for a better Setup Builder and some of my friend recommend InstallAware to me.
I did saw and read some differences between InstallSheild and InstallAware. May i know more defference ??
Besides that, i have another question to ask which is can my file being overwrite when i make a major or a minor update?
When i am updating my program will the setup i build will overwrite the file automatically or i have to do it manually.
Besides that, if i am using a web confict file to control my program, can the command that i had selected and used will be overwrite after i had made a minor or a major update??
thanks in advance,
jason
Postby CandiceJones » Tue Feb 03, 2009 8:47 am
Please state your questions more clearly and in correct English. Thank you.
Return to “Non-Technical”
Users browsing this forum: No registered users and 35 guests
