Can I add the runtime for MS Access to the Application Runtimes?
How would I do this and how would I check for its existance on the target pc. My current installer does a componentID check in the registry.
I also need to check the SP of MS Office 2003 to be SP3 or later, same applies, how do I add SP and check or its existance.
Thanks in advance
MS Access 2003 Runtime
You can use Read Registry, Is MSI Setup Installed, and similar MSIcode commands for this task.
You should also read our whitepaper which describes custom application runtime creation.
Hi Candice,
I'm designing a custom application runtime which uses a non-MSI package, non IA built-in command installation. I think I should use the Run Application command in order to invoke the installation of my runtime, but where can I find its file? Should I include it as a support file? How should I proceed?
Thanks in advance!
Thanks in advance!
[b]Tiago Rocha[/b]
[i]Product Technology[/i]
www.ppi-multitask.com.br
