Patching files that were modified after the original install on the host machine left the files untouched. That is they were not overwritten by the new version. Is this the default behavior? Can we force the files to be overwritten?
I'm using Web Build btw.
Dawid
Patching modified files
Found the answer:
Versioned File
Versioned File
- 1. If the file version on the target system is the same as that in the setup package, the file is not updated, irrespective of the date.
2. If the file version on the target system is older than that in the setup, the file is overwritten.
3. If the file version on the target system is newer than the file within the setup, it is not overwritten.
- 1. If the file on the target system has a later modified date versus created date, it is not overwritten, as it is considered user data.
2. If the file on the target system has the same created and modified date, it is overwritten.
3. If the file on the target system has a created date that is later than the modified date, it is overwritten.
