I can't figure out where InstallAware keeps the path to where dialogs and support files are kept on disk. I had my project in a directory and now copied everything to another directory for a new version of my product, but when I add a dialog to the project it places it in the old directory, and when I try to modify/save one of the existing dialogs in the project, it is trying to modify them from the old directory, not the new one.
How can I change which directory is being used to store these files?
Zvi
Where is path to dialogs stored?
The MPR file defines the project directory. You can read the help file which describes all the other files that are a part of your project and how they are moved around.
