When I go to uninstall the program...
Click remove, then it goes to the uninstall screen. Uninstall is selected and click next... goes to the Completing Installaware wizard screen and click next.... A browse for folder screen pop-ups that says please locate your original setup sources to operation. I don't know where that is... so if I click OK... it does nothing it stays on the same screen but if I click cancel it gives a Runtime error in setup
script:
Line 428: Original setup sources required to complete operations, sources not found.
Uninstall Issue
The line number doesn't make sense. I'm just installing a graphic, along with 40 more. Why that one?
Install Files C:\\Users\\Dan\\Desktop\\PointOS Professional Install Files\\Database\\Buttons\\bass.bmp to $MYDOCUMENTS$\\PointOS Professional\\Buttons\\ (Permanent, Never Overwrite)
Line 428:
Install Files C:\\Users\\Dan\\Desktop\\PointOS Professional Install Files\\Database\\Buttons\\becks.bmp to $MYDOCUMENTS$\\PointOS Professional\\Buttons\\ (Permanent, Never Overwrite)
Install Files C:\\Users\\Dan\\Desktop\\PointOS Professional Install Files\\Database\\Buttons\\blank.bmp to $MYDOCUMENTS$\\PointOS Professional\\Buttons\\ (Permanent, Never Overwrite)
Line 428:
eugen.cocalea
There is a topic that gives you a solution for this, I am too lazy to search for it again, but what you have to do is basically make your installation a Compressed Web-Based Exe (instead of a Single Self-Installed Exe) and enclose all your code in a single web media block with no name. This will fix this error.
