In the documentation regarding Application Updates it states:
"Upon the first logon of the end-user after product installation, a message balloon will request the end-user to schedule regular update checks, and determine how interactive they run. The end-user may choose any desired schedule and may opt to manually our automatically download and/or install updates. The update script will then create a scheduled task reflecting the end-user preferences. Until the scheduling step has been successfully completed, no update checks may occur."
Is there any way to not get the user involved and automatically schedule regular update checks?
Thanks...
Scott
Receive Application Updates
Yes of course, by customizing the MSIcode script you may achieve this objective within your own pre-set schedule or there is essentially no limitation on what you can try.
Users browsing this forum: No registered users and 35 guests
