One of our support people at work asked me if IA can install Windows PowerShell on appropriate machines. I mentioned we can detect whether the OS is compatible for PowerShell and if it is installed I might find a trace of it in the registry but installing it will be a different issue. The best I can think of is that I might have to include the WPS setup as a support file or in a file bag, and then launch it during installation where it's appropriate.
Then again perhaps there is a merge module type of thing that can handle that? If you have any strategies or suggestions I'd appreciate them.
Windows PowerShell.
Windows PowerShell.
