Uninstall Slient never finishes
gduke
Post by gduke »
I am running a a silent uninstall with the following cammand line:
<mysetup> /s ADVERTISE=FALSE MODIFY=FALSE REMOVE=TRUE UNINSTALL=YES
yet the uninstall never finishes in task manager. Any suggestions?
Most probably a coding error in your script is causing this to happen. You can try to debug this inside the IDE by setting the SILENT pre-defined variable to TRUE in the script.
