Authenticode
fxtech
Re: Authenticode
Postby fxtech » Tue Jan 11, 2011 9:04 am
I followed those directions to convert my .p12 (same as .pfx) cert to a .spc and .pvk file and InstallAware gives a generic error when it gets to the code-signing part and won't continue.
What am I missing?
dunion
Re: Authenticode
Postby dunion » Tue Jan 11, 2011 9:09 am
I had that same trouble and it caused me lots of head scratching. Then I found out that our certificate had expired and been renewed to a new certificate instead of renewing the 'same one' by Verisign, so I just needed the new certificate. Make sure your certificate is still valid (check date).
fxtech
Re: Authenticode
Postby fxtech » Tue Jan 11, 2011 9:21 am
Thanks for the reply, but the certificate is brand new.
One step in those instructions however didn't work. On this line:
openssl rsa -in MyKeyTmp.pem -outform PVK -pvk-strong -out MyCert.pvk
-pvk-strong was an unknown argument, so I removed it and it worked. But as I mentioned InstallAware didn't like the resulting file(s). Wish it would provide more information about what the error is.
crilando
Re: Authenticode
Postby crilando » Tue Jan 11, 2011 9:31 am
thank you for the info. I will check with the newes downloads and will actualize the documantation.
chris
giaviv
Re: Authenticode
Postby giaviv » Sat Sep 03, 2011 12:05 pm
Hey guys,
Just to let you know, InstallAware now was built-in PFX support!
Users browsing this forum: Google [Bot] and 201 guests
