I cannot find a way to change the update icon. I need to change it because it is the same one used for the program (I don't want to confuse my customers).
Is there a quick and easy way to change this?
I am using IA Studio 8.
Change the Update Icon in SysTray
Rocky, the icon is the same as your setup's icon. If you want a different icon, change the setup icon; or build your update client separately and specify a different icon in that separate project.
