VisualBasicScript - seem doesnt work
Bar_BQ
Post by Bar_BQ »
I'm trying to run a visual basic script through the function "Run program as" with command:
wscript.exe $SUPPORTDIR$\\my_script.vbs
That script should generate a text file, but it looks it doesn't work. The script itself works fine.
Could anybody help?
bokkie
Post by bokkie »
Bar_BQ,
Does it write output to the DOS window? If so, you might need to redirect the output to a text file and read that in your MSIcode. I don't recall the syntax to hand but something like:
wscript.exe $SUPPORTDIR$\\my_script.vbs > C:\\Temp\\my_output.txt
If your script writes to a text file directly then you can certainly read that file as well.
Bar_BQ
Post by Bar_BQ »
Thank you bokkie for easy solution :)
bokkie
Post by bokkie »
Bar_BQ wrote:Thank you bokkie for easy solution :)
You're welcome. You can send the $5K fee to me. :lol:
bmenot
Post by bmenot »
does this actually work? what i mean is, does the redirection work outside the command shell?
The shell is just cmd.exe which has command line parameters suitable for your requirements viewable by running cmd.exe /?.
