The use of compiler variables to customize setup at build time and have setups for different products is really a nice feature to have, when only very few things change between them, having a unique setup project.
However, how such approach doesn't break the Patch requirements when the elements that I need to have different are: Product Name, Product Code, Product Version and files/features and such differentiation breaks the Patch Requirements?
Break of Patch Requirements
Use whatever names you like, and enter in those variables using the form #NAME# into the respective hard coded fields. Then just use whatever values you like for those newly created compiler variables (use the Project Options dialog to define them, and you can assign/override default values there, or use the command line build tool).
