I need to add some files after the installtion. What whould be the best method to perform this task?
For an example, lets say that I have already installed the software. In the new version i need to add some more files. How can this be done without uninstalling the prevoius version?
Lilan
How to add files after installtion
Another option is to create a new feature in your project and add the new files to it. If you then run the installation you can then select the customise option and then select the created feature. That will then install only the new files you want to add.
The company I work for develops softwares. So lets say that they have released one version of the software. In the new version, there r only some files added to the software. So what they want is, not to uninstall the pervious version. Just to add the new files when the new installer is executed.
On the replies that I got, for the second one, once u create a new installer it automatically uninstall the previous version and installs the new version right.
I need a way to work around this if possible.
Lilan
Lilan
Seems we have misundersood each other. For me, the best solution is to create a patch, despite IA claims it's not for making updates, just patching. There are no official information, any white papers, nothing about it... and I suppose there would be quite a lot users who want to know how to do this correctly...
Actually, there is a whitepaper on patching. On www.installaware.com -> Support-> Publications -> WhitePapers -> Using InstallAware to Patch Software Products.
To use patching, your script needs to be pretty stable (least amount of changes), that's why I did only some tests so far and am not using it for production.
Rgds
Richard
Rgds
Richard
http://www.pointline.com
http://www.paraeasy.ch
http://ulrichard.ch
http://ulrichard.ch
You can always write some custom code to manually copy files using the WinAPI via Call DLL Function.
Patching also ought to work with new files, but as it has been mentioned, your scripts should be well-structured for the MSI engine to detect changes and new files successfully.
You can even preserve your old app settings so re-installs automatically leverage them, you can do this with pre-defined compiler variables or MSIcode script commands which load/save feature selections, and so forth.
Why not try with a patch to start out with, I know we have customers pushing new files successfully with that method...
