Important mdPLUGINS update for InstallAware 9 users
casic
Post by casic »
Hi there,
the new version 1.2.6 of mdPLUGINS for InstallAware fixes compatibility issues with InstallAware 9 and above. All included plug-ins are now fully compatible with all versions of InstallAware starting from 5.31. If you are using mdPLUGINS we strongly recommend to update to version 1.2.6 which can be downloaded here:
mdPLUGINS for InstallAware 1.2.6
Thank you,
Markus
Markus Diettrich
Install[b]Aware[/b] MVP
[i]If it can't be done with InstallAWARE then you are not using Windows[/i]
