Native Images are not created under .NET 2.0.
I'm calling Generate Native Images after Apply Install for $TARGETDIR$\\application.exe.
Is that correct?
What can I do?
I'm also missing the option queue for generating the native images.
Thanks, Anton
Hi Anton!
The queue option is not available - but you can always run ngen.exe using the Run Program command and manually specify this option.
Native images are supported under .NET 2.0, but you need to be using the latest version of InstallAware for this - just download the trial for version 5.0.
Hi Anton
How are you specifying the assembly names in the command? We'll get it working for you...
Hi!
Did you try running ngen from the command line, to see if there is an error?
Thanks!
Thanks!
Not a problem, glad to hear it works
Users browsing this forum: Baidu [Spider], Bing [Bot] and 15 guests
