Write variables to XML file?
pointeman
Post by pointeman »
Does InstallAware write variables to a Microsoft XML file?
Post by CandiceJones »
Sure, use the Edit File plug-in.
pointeman
Post by pointeman »
Can you point me in the correct direction? I don't know anything concerning InstallAware plugins. I did not find any information in the local Help either.
Just download the plug-in from the Plug-Ins section of this forum :)
pointeman
Post by pointeman »
Well the only problem now is the EditINI plugin does NOT write conventional XML format. It writes settings like [SQLCON] instead of <SQLCONN>. I've read other posts where the pro's say the EditINI can write to any file, but I thinkd the EditINI is a very specialized plugin. I think InstallAware needs a specialized EditXML plugin as well. XML files are very popular theses days....
