I am trying out the caching of the setup sources in a single file install.
I am noticing that it's leaving behind a number of executable files (DLLs, EXEs, etc.) that are not signed. This will cause Vista certification to fail.
Is it possible to cache the setup sources as an MSI instead of flat files?
If not, how can we make a vista certifyable install that allows modify/repait to work with a single file install?
...Matt
Install Cache Leaves Unsigned Executable Files
It's not an InstallAware issue. Any installer which would cache files would run into this issue. Sign your files! Or, if they are runtimes, nuke the runtime folders post-install to ensure they don't get in the way.
The other installer used to cache the MSI and would access that during modify/repair.
All of our files are digitally signed.
The files being left behind are files like:
C:\\ProgramData\\...\\mWinRun.DLL\\mWinRunExec.DLL
C:\\ProgramData\\...\\mWinRun.DLL\\ansi\\Cabinet.DLL
C:\\ProgramData\\...\\mWinRun.DLL\\ansi\\msihnd.DLL
So you're saying it's safe to just delete these? And modify/repair will still work?
...Matt
...Matt
These are runtime installer files. Like I said, it will be safe to delete the whole folder. And no, even the other installer does not put runtime files inside the MSI
