i use the Sample MS SQL Server Connection to generate a Database Setup. On some Systems I get a Error Message "Line: 38 " is not a valid integer value".
The Code I use in Line 38 is: Detect MS SQL Instances : get result into variable AVAILABLESERVERS.
And the variable is set with the code: Set Variable AVAILABLESERVERS to in Line 24
BR
Michael
\" is not a valid integer value
Michael_Alber
I use InstallAware 9 SP1.
Ensure that you have installed the latest trial version from the public website, and then re-generated and re-installed your latest license from your private customer website.
If the issue still recurs, send us a virtual machine which reproduces it.
