Merge Modules
BigApe
Merge Modules
Postby BigApe » Thu Jun 25, 2009 6:24 am
Hello
Can InstallAware be used to create Merge Modules?
BigApe
Postby BigApe » Thu Jun 25, 2009 9:11 am
Hi I've found the answer to this in an older post, you cannot create merge modules with InstallAware.
DanStutzman
Postby DanStutzman » Thu Jun 25, 2009 1:28 pm
If you don't want to spend money on IS/WPS to create a MSM, you can use ORCA and then follow the guidelines from this article:
http://msdn.microsoft.com/en-us/library/aa367783(VS.85).aspx
Postby CandiceJones » Thu Jun 25, 2009 10:57 pm
We also have WiXAware (www.wixaware.com) which does let you build merge modules, but the recommended way of code re-use in InstallAware is by using the Include Script command.
Return to “Non-Technical”
Users browsing this forum: Google Adsense [Bot] and 46 guests
