Hello Friends
Can you explain me..is this possible the creating setup file to install in only one system..
Thank you...
Is Possible the creating setup install in only one system
sathishmca
sathishmca
Don't expect anybody here to build your setup for you. We're here to empower you to get your job done, not to do it for you
If you have a specific issue you're stuck on, just post back
sathishmca
Chris Miller
Re: Is Possible the creating setup install in only one system
If I understand you correctly, one install per machine is the pretty much how Windows Installer works.sathishmca wrote:Hello Friends
Thank you...
Did you mean having a setup work only only a single machine? If you are trying to keep an application from being installed in multiple places, you would need to code that check yourself. You would have to come up with some sort of validation scheme and then do that validation early on in the installer. If your validation checks, you would display some message to the user and gracefully terminate the installer.
Chris Miller
[url=http://www.versatrans.com]Tyler Technologies[/url]
[url=http://anotherlab.rajapet.net]My blog[/url]
[url=http://www.linkedin.com/in/christophermiller]My LinkedIn profile[/url]
