Minimal Installation
asparagusx
Post by asparagusx »
Hello
I have been looking through the documentation regarding the options available of what will/not be installed during a Minimal Installation. How do you define what should be installed during a Minimal Installation?
Anton
It's defined in your MSIcode script. You can customize it there per your liking. I believe by default the visual IDE emits code such that only your "always installed/feature independent" files are enabled for a minimum install.
