Delete Folder?
DanStutzman
Delete Folder?
Post by DanStutzman »
Did I just discover that there is no way to delete an existing folder within InstallAware? How did that fall through the cracks?
Chris Miller
Post by Chris Miller »
Can you do something like this with the "Run Program" MSIcode command:
Run Program cmd.exe /c rmdir /s /q "c:\\somefolder"
Chris Miller
[url=http://www.versatrans.com]Tyler Technologies[/url]
[url=http://anotherlab.rajapet.net]My blog[/url]
[url=http://www.linkedin.com/in/christophermiller]My LinkedIn profile[/url]
Another implementation would be using Call DLL Function on the RemoveDirectoryA WinAPI call in kernel32.dll. Returns a BOOL, the single parameter that specifies the folder location is a LPCTSTR.
Call Delete Files Recursive first if the folder is not empty.
