I am using InstallAware Studio Admin 9.03 via command line (miabuild.exe) to build my installers. Although I use the /R switch to auto-generate a new revision code with each build, this function does not appear to be working (when I install Build 0001, then install Build 0002, the later build brings me to a Repair Install).
This used to work fine in InstallAware 7. Did the command line parameters change? Is this a known bug in InstallAware 9.03?
For now, I'll manually set a new revision code via the InstallAware IDE before each build, but I'd like to get back to my scripted builds soon. Any help would be great.
- Michael
Revision code not updating with command line build
MikeOnline
Hi, Mike!
Have you try this parameter in lowercase (/r instead of /R)??
I would advise to upgrade to version 9.06. But i can sure you this functionality is fine. We used all version from 9.0 till 9.06 and our automation build worked with /r parameter. Q&A team did not even mentioned about upgrade problem.
Best regards!
Best regards!
