DLL CALL SHGetFolderPathA in $WINSYSDIR$shell32.dll
Alexander
Post by Alexander »
Hello everybody,
I have a problem to get the path of CSIDL_COMMON_APPDATA
of the function SHGetFolderPathA in $WINSYSDIR$shell32.dll
CSIDL_COMMON_APPDATA has the hex value 0x23, dec 35.
Here is a copy how I call the dll in IA
~InstallAware Clipboard Data~
~Call DLL Function~
~{06A156FA-C585-45D9-9216-0BDEDB8CD315}~
~$WINSYSDIR$shell32.dll,SHGetFolderPathA,"double word",LASTERROR,long,0,long,35,long,0,"double word",0,"pointer to string",$TARGETCOMMONAPPDIR$,$~
~mIDEFunc.dll\\mEXEFunc.dll~
But the variable $TARGETCOMMONAPPDIR$ which should held the result / directory of SHGetFolderPathA, is empty.
MSDN link:
http://msdn.microsoft.com/en-us/library ... S.85).aspx
So what is wrong.
Thanks a lot for your help.
Did you try using Get Folder Location instead? Its got a quite extensive list of pre-defined folders, etc.
figo
Re: DLL CALL SHGetFolderPathA in $WINSYSDIR$shell32.dll
Post by figo »
Hi Michael,
I too am attempting to use this function and was wondering if there solution you provided to Alexander addressed his inquiry?
I keep getting a DLLLOADFAILED when involking both SHGetFolderPath and/or SHGetFolderPathA.
- L
If all else fails, Improvise!
http://www.luiscasillas.com
Post by mills »
Alexander,
Are you sure that you are pointing to the DLL properly (full path)?
figo
Post by figo »
I was able to solve my issue with the following code:
~Call DLL Function~
~{81809BBC-11B9-4463-9A38-42B300ED2C02}~
~$WINSYSDIR$Shell32.dll,SHGetFolderPath,"double word",FILE_HANDLE,long,NULL,long,35,long,NULL,"double word",SHGFP_TYPE_DEFAULT,"allocated string buffer (MAX_PATH length)",$APPDATA_PATH$,$~
~mIDEFunc.dll\mEXEFunc.dll~
