In InstallAware 9.06, if you try to read this value into the same variable, it will hang.
InstallAware fixed WRITE REGISTRY at some point so if the data were an expanded variable, and that variable was empty, an empty string would be written. But READ REGISTRY still needs to be fixed, so it can read such values (such as user registration data) written by older InstallAware installers.
Below is an MIA script that will illustrate the problem. It will prompt you at one point to modify a registry value using REGEDIT so it appears the way that older InstallAware installers would have written it.
A work-around is to read back such values using a different variable name than was used in the older InstallAware installer (illustrated in the example).
- Michael
Note: could not successfully paste the code sample as InstallAware clipboard data into this post
[OFFLINE CONTENT]
Comment: Test InstallAware 9 MIA script -
Comment: AppHang when reading a registry value with data equal to the variable name surrounded by dollar signs
Comment: (this is how early versions of InstallAware 7 saved registry values contained in a variable set to an empty string)
if Variable REMOVE Equals TRUE
Apply Uninstall (get result into variable SUCCESS)
Set Variable PROGRESS to 100
else
Set Variable Phone to (415) 555-1212
Set Variable Fax to
Set Variable SerialNo to 12345
MessageBox: $TITLE$ Setup, Finished setting user registration variables, which are currently:$NEWLINE$$NEWLINE$Phone = $Phone$$NEWLINE$Fax = $Fax$$NEWLINE$SerialNo = $SerialNo$$NEWLINE$$NEWLINE$Fax is intentionally set to an empty string.
Write Registry Key HKCU\\SOFTWARE\\MyTestApp\\Phone, $Phone$
Write Registry Key HKCU\\SOFTWARE\\MyTestApp\\Fax, $Fax$
Write Registry Key HKCU\\SOFTWARE\\MyTestApp\\SerialNo, $SerialNo$
MessageBox: $TITLE$ Setup, Finished test installation, which saved user registration values in the Registry.$NEWLINE$$NEWLINE$About to read back these user registration details from the Registry.
Read Registry Key HKCU\\SOFTWARE\\MyTestApp\\Phone into Phone
Read Registry Key HKCU\\SOFTWARE\\MyTestApp\\Fax into Fax
Read Registry Key HKCU\\SOFTWARE\\MyTestApp\\SerialNo into SerialNo
MessageBox: $TITLE$ Setup, Finished retrieving user registration details -- $NEWLINE$$NEWLINE$Phone = $Phone$$NEWLINE$Fax = $Fax$$NEWLINE$SerialNo = $SerialNo$$NEWLINE$$NEWLINE$If the Fax value had been saved using an early version of InstallAware 7, it would have been saved to the Registry as the word Fax (surrounded by dollar signs). InstallAware 9.06 will hang if it tries to read such a value. To test, run REGEDIT now and set the value of HKCU\\SOFTWARE\\MyTestApp\\Fax to %Fax% (except use dolar signs rather than percent signs). Then click OK to re-read these values.
Read Registry Key HKCU\\SOFTWARE\\MyTestApp\\Fax into Phone
MessageBox: $TITLE$ Setup, Able to successfully read value Fax ($Fax$) into variable Phone.$NEWLINE$$NEWLINE$Will now try reading the same value into variable Fax.$NEWLINE$$NEWLINE$
MessageBox: $TITLE$ Setup, Able to successfully read value Fax ($Fax$) into variable Fax.$NEWLINE$$NEWLINE$
