deco0_07
Posts: 9 Joined: Mon Aug 31, 2009 2:20 pm
Post
by deco0_07 » Mon Aug 31, 2009 2:23 pm
I downloaded version 9 of InstallAware, but when I chose an icon and run the single file, show me the error "
is not a valid win32 application". I change the icon, to many formats, but the problem continues.
i saw the older topics, mas not resolved
Anybody help me?
any thing ask me...
André
neillans
Posts: 536 Joined: Sat Nov 04, 2006 6:21 am
Post
by neillans » Mon Aug 31, 2009 3:40 pm
Hi Andre,
I am afraid to say that the error indicates you have an invalid / corrupt download, and you will need to clear your browser cache and try again.
Andy Neillans
deco0_07
Post
by deco0_07 » Mon Aug 31, 2009 3:49 pm
Sorry ... forgot to comment ... If I remove the icon, it works perfectly. But I will try your suggestion tomorrow and post the answer
André
deco0_07
Post
by deco0_07 » Mon Aug 31, 2009 3:52 pm
other comment...I have the version 8 and the problem is the same
André
deco0_07
Post
by deco0_07 » Tue Sep 01, 2009 7:08 am
The file is not corrupted...anything else what can i do?
I just wanna put icon in my setup..
André
neillans
Post
by neillans » Tue Sep 01, 2009 2:46 pm
Can you try another icon? Sounds like it must be that causing the problems but not sure why. If another icon works, I think you will need to submit your ico file
Andy Neillans
deco0_07
Post
by deco0_07 » Tue Sep 01, 2009 3:18 pm
Hi!!!
I try with other icon, but the problem continues...
could you send to me an icon, that works for you, to test?
My emais address is
[email protected]
André
deco0_07
Post
by deco0_07 » Wed Sep 02, 2009 11:41 am
Hi Andy!
thanks for the icon, but the problem continues...There is some more test?
i am almost given up...
Thanks for the help!
André
neillans
Post
by neillans » Wed Sep 02, 2009 2:01 pm
Hmm - so it works as normal with no icons (except the InstallAware default icon) ?
Are you using a purchased version or the trial?
Andy Neillans
deco0_07
Post
by deco0_07 » Thu Sep 03, 2009 6:40 am
Works normal with the InstallAware Default Icon...
I use the trial version...
anyway...thanks...I use the default icon..i will wait for new version for test..
thanks Andy, can close the topic
André
Windozer
Posts: 3 Joined: Wed Dec 16, 2009 4:23 pm
Post
by Windozer » Wed Dec 16, 2009 5:24 pm
Same problem, same conditions.
