I have implemented languages into my install. I have added the drop down box for language selection before my install, but it's so small that translated text gets cut off. This happens on nearly all my languages.
How do I adjust the size of that box so that any translated text will fit?
Adjusting size of language select drop down box.
Most of the information needed to construct a custom language selector can be found on the forums -- however, start off by reading this one http://www.installaware.com/forums/viewtopic.php?t=4805.
That gives you the variables to work with.
As far as I know there is no variable that lists the available localisations.
Andy Neillans
Re: Adjusting size of language select drop down box.
Is there a solution regarding adjusting the size of dialog or text?
the solution is the one defined before, you should create your own Language selector dialog.
