InstallAware v5.01 Update
Post by CandiceJones »
You may now download the InstallAware v5.01 update from the public download page.
This update addresses the issues below:
  • The $CMDLINE$ pre-defined variable occasionally lost its first character
    The IDE did not update the Pattern or Position field of the Parse String function
This update introduces the new functionality below:
  • Compiler variables are now resolved when used in string fields of the Project Options window
    The Install Files command now offers a new Exclude Wildcards field to allow excluding files and/or folders from a build
If you are not affected by the above issues, you do not need to update.
