Windows 2008 SBS & Windows 7
paul.fitzpatrick@avondata
Post by paul.fitzpatrick@avondata »
When installing on to Windows 2008 SBS or Windows 7. Non of the prerequisites are installed. The installer tells you: "<pre> could not be installed. Please use the Windows Update to manually install this update on your system"
Is there away round this?
neillans
Post by neillans »
Afraid there is not much to go on this!! Can you say what pre-reqs are included? Have you broken down and tested each pre-req to identify the specific one?
Andy Neillans
Tiago
Post by Tiago »
Maybe you're trying to run 32bit applications on a 64bit platform?
[b]Tiago Rocha[/b]
[i]Product Technology[/i]
www.ppi-multitask.com.br
