MS SQL Server plug-in & variable for SQL Script
valerio
Post by valerio »
Hi All;
The Plug-In "MS SQL Server" executes a SQL Script fine as long as the script ist static. Is it possible to use a Variable instead of the static text? Or is there a way to tell the Plug-In to load a script file at runtime?
Or in the worst case: do I have to write my own Plug-In?
thanks for any hint
Arno
KennethLee
Post by KennethLee »
Actually, from what I've tried, you can put in variables into the SQL script. I do so in my current install and it seems to work fine.
I use $<variable>$ within the sql script. Try that and see if it works.
valerio
SUCCESS
Post by valerio »
SUCCESS is the result of the script!!
Thanks for your help.
Arno
