StyX
Post
by StyX »
Is there a way to check if a folder already exists on the target system and check if that folder is empty?
ChrisN
Post
by ChrisN »
Hi.
You can use "Does File/Folder Exist" to check for a folder and "Find All Files" if you want to know if it is empty or not.
Hope this helps.
StyX
Post
by StyX »
Thanks, I can't believe that I missed that in the commands list
