Express version can install new fonts?
drylight
Postby drylight » Sat Jan 08, 2005 8:27 pm
I was wondering if with the Express version it was possible to install a new font into a Windows machine?
Regards,
Diego
sinan
Postby sinan » Sun Jan 09, 2005 5:42 am
I believe so. Put your fonts under a Fonts folder. Then add that whole folder (as a folder in the Express gui) inside the Windows folder.
Guest
Postby Guest » Sun Jan 09, 2005 6:01 am
Thanks for taking the time to reply. I will try your suggestion.
Regards,
Diego
Return to “Non-Technical”
Users browsing this forum: No registered users and 13 guests
