Backup of files
jimo
Backup of files
Post by jimo »
Anyone have any thoughts on how to create a copy of files before the Pre-Requiste uninstall runs? You can't use copy/move local files because that requires an apply install action.
Call CopyFileA / MoveFileA Win32 APIs using Call DLL Function - both should be in kernel32.dll.
jimo
Post by jimo »
Thanks for the quick response.
This is what I've got;
~InstallAware Clipboard Data~
~Call DLL Function~
~{D0DAB771-1924-4F18-97AB-F6EB5F25C835}~
~kernel32.dll,CopyFileA,bool,LASTERROR,"pointer to string",$APPDIR$\\Miner\\Common\\reports.*,"pointer to string",$APPDIR$\\Backup\\reports.*,$~
~mIDEFunc.dll\\mEXEFunc.dll~
~Call DLL Function~
~{8FC05693-7421-4381-9815-EE44430F14AD}~
~kernel32.dll,CreateDirectoryA,bool,LASTERROR,"pointer to string",$APPDIR$\\Backup,$~
The directory is not being created in the first dll call so the subsequent copy command fails. Any more thoughts? (Why do they paste in reverse order?)
CreateDirectory needs an additional parameter, according to MSDN?
