Howto Limit OS during setup ?
dcube
Post by dcube »
I see about minimun OS, but it's possible denied for a specific one ?
In other words , it possibile denied setup if the OS is Window 7 (or Vista or Any server) ?
Best regards
dcube
neillans
Post by neillans »
Sure :) We do not support this through our GUI portion, however, you can modify the MSI Code to add this specific check.
Andy Neillans
dcube
Post by dcube »
Hi neillans,
thank you for reply.
I'm a newbe so did you now where I can find a sample about taht (or similary) ?
Best regards
dcube
Bar_BQ
Post by Bar_BQ »
Hi dcube, it's simple, use "Get System Settings" function. Under this function you'll find all the necessary contraints that you want to make.
