Else If?
Archannon
Else If?
Postby Archannon » Wed Jan 18, 2006 12:07 pm
Ok.. feeling a little uptarded here. I'm creating a nested IF statement and would prefer to use Else If. However, when trying to either type it in or looking for it in the command list, I'm unable to locate it. InstallAware doesn't seem to recognize the command. I checked the help file to verify that it's supposed to be there and it's listed. I've only got the 30 day eval copy, but this is kind of a critical point for our scripting purposes. If the 30-day eval copy doesn't have all the commands, I can deal with that.
Is there a special magic trick I'm missing on this one? Any help would be appreciated.
Henry J.
Gizm0
Postby Gizm0 » Wed Jan 18, 2006 1:40 pm
Can you please be more specific on what exactly your problem is , or even better attach your script so i can review it and help you?
Thank you!
Panagiotis Kefalidis
Software Design Team Lead
Archannon
Postby Archannon » Wed Jan 18, 2006 1:51 pm
Summary: I can't find the 'Else If' command in InstallAware. I have If, Else, and End... but no Else If. Checked everywhere I could logically think of, but no luck on my part. Just looking for a little help.
Henry J.
Gizm0
Postby Gizm0 » Wed Jan 18, 2006 2:05 pm
Archannon wrote:Summary: I can't find the 'Else If' command in InstallAware. I have If, Else, and End... but no Else If. Checked everywhere I could logically think of, but no luck on my part. Just looking for a little help.
Henry J.
Actually there is no need to use Else If.
You can achieve the same result by using If and End.
eg.
If VARA is True Then
execute/set your stuff here
End If
If VARB is True Then
End If
I hope i was helpfull!
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 94 guests
