First ListBox item selected by default
Post complete new themes or wizard dialogs here.
abdou24
Postby abdou24 » Mon Nov 23, 2009 3:40 pm
I'm using a list box in my dialog sample, and would like to know how can i set the first item of my list box to be selected.
I try to play with all the control option but still cannot figure it out.
Any idea?
Postby MichaelNesmith » Mon Nov 23, 2009 3:56 pm
Actually, you do it by pre-setting the variable that the control is bound to, to the target value you want to have pre-selected in the control.
abdou24
Postby abdou24 » Mon Nov 23, 2009 4:11 pm
Thank you for the quick reply.
I've tried to pre-set the variable bound to the list box but still the same thing.
Here is my project
PPSUITEINSTALLERPROJECT.zip
mikKummerfeld
Re: First ListBox item selected by default
Postby mikKummerfeld » Wed Apr 18, 2012 10:16 am
it does not work...any solution ?
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Postby FrancescoT » Thu Apr 19, 2012 2:25 pm
You should set the variable that the box writes to, to the item to select.
Example:
Set Variable MYLISTBOX to Two (Where Two is one of the String Item in the listBox)
Then in "Object Behavior" of the ListBox, Write Values to Variable assign "MYLISTBOX".
mikKummerfeld
Postby mikKummerfeld » Fri Apr 20, 2012 12:27 am
it works with combobox but not with listbox.
SET LISTBOXITEM to Product A does not preselect Product A
Combobox OK
Kind regards
Heiko Kummerfeld
MIK GmbH
Postby FrancescoT » Fri Apr 20, 2012 7:25 am
It works .. I have just tested!
Send me a very simple project that replicate the issue and I wiil have a look.
Return to “New Themes, Dialogs”
Users browsing this forum: No registered users and 0 guests
