Hi there,
Just today i have begun receiving errors with my setup package.
Error
Could not write VersionMajor top key \\Products\\C934...E4\\InstallProperties. Verify that you have sufficient access to that key, or contact your support personnel
if i chose to ignor the error i get another
Error
Could not write VersionMajor top key \\Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\{9CD..ProductCode..R4}. Verify that you have sufficient access to that key, or contact your support personnel.
If i ignore again the setup completes.
Can anyone shed some light on what is the problem here?
Cheers
Richard
Registry access error
Hi Richard
I believe you are using a non-numeric version number for your setup. Please make sure the version you are setting for your project is numeric only, of the form major.minor.revision, such as 1.0.2006.
Users browsing this forum: No registered users and 65 guests
