Install feature via MSI API
iti
Post by iti »
we have the following feature structure in our setup(simplified):
1. Base Program
2. Sample Files
What we want to do is install feature 2 when the user requests a sample file inside the main application. This should be no problem as MSI has an API and an API function that installs a feature from an MSI-File:
http://msdn.microsoft.com/en-us/library ... 85%29.aspx
When we tried to call the "MSIInstallMissingFile" Feature we have to provide the product-guid (which is no problem) and the filename of the file to be installed (this doesn't work). I had a look at the MSI with "Orca" and I saw that there are no real "Features" in the MSI like I defined in InstallAware. We have 15 Features defined in the setup but 793 features in the table. An there are no real identifiers in Title or Description that I can access only cryptic feature IDs.
When I try to access the "Filename" property in the "File"-Table the MSIInstallMissingFile() function fails with a "FileNotFound"-error. I tried all name structures "Shortname|Longname", "Shortname" and "Longname" only. Nothing works.
What am I doing wrong? Is there another way to install a feature from inside an application or are the MSI files that Installaware generates no real MSI files?
Thank you in advance,
Ciao,
Sven
