Setting Service dependencies
figo
Post by figo »
Anyone know if there is a way to setup Service Dependencies on services being installed via IA?
Basically I need to make sure that one of the services (both installed with automatic settings) is only started after the second service I am installing.
I came across this article:
http://support.microsoft.com/kb/193888
but was wondering if there is a way to install the services without using the "Run Program" command?
Will updating the registry after the installation be my only other option?
thanks in advance
If all else fails, Improvise!
http://www.luiscasillas.com
