Problem with InstallAware Express Edition for Delphi 2010
snackmoore
Post by snackmoore »
Hi There,
I am using the InstallAware Express CodeGear Special Edition,
Based on InstallAware 7 Release 2.
I tried to build a installation disk for my Delphi 2010 application,
and I checked the following Application Runtimes
- CodeGear Database Express12
- CodeGear Visual Component Library 12
and when I try to built it, I'll get the error message,
No files matching pattern "C:\\Windows\\system32\\\\*120.bpl"
for what I understand, the packages from Delphi 2010 are *140.bpl and *120.bpl are for the previous version.
Since the version of InstallAware that I'm using comes with Delphi 2010, can someone tell me
if I am doing something wrong?
or if it is a setting that I could change?
or there is an update available?
or I am crazy to even try?
Please help....!!!
Post by CandiceJones »
Please contact CodeGear for support with your product. Thank you!
snackmoore
I see.... So this InstallAware Special Edition for Codegear Delphi 2010 is not supported by InstallWare?
Because I post there also and is a general perception that it is an InstallAware product.
Because InstallAware doesn't make a dime from this bundling, our agreement with CodeGear is that they are required to support the product.
