The scripts I created were approved by my project-manager and I have the approval of purchasing InstallAware.
That brings me up to the next problem.
The time I've been testing InstallAware I've stored the projects on the local disk of my laptop.
The setup containes up to 54 files to be installed, and are stored inside the project like this :
Install Files C:\\IAProjects\\Case_1\\File1.dll to $WINSYSDIR$
Install Files C:\\IAProjects\\Case_1\\File2.dll to $WINSYSDIR$
Install Files C:\\IAProjects\\Case_1\\File3.dll to $WINSYSDIR$
...A couple of questions:
1)
Will the mpr-file load correctly if moved?
2)
How can I quickly change the pathnames [C:\\IAProjects\\...]
without having to change all of the 54 files manually.
3)
Can we use servernames or must we use Drive-letters?
"\\\\Servername\\Projects\\Project_1\\Setupscript\\" or "N\\Projects\\...."Can we use (compiler) variables to store the sourcepaths ?
like this:
Set Variable $SOURCEPATH$ to "\\\\Servername\\Projects\\Project_1\\Setupscript\\"
Install Files $SOURCEPATH$\\File1.dll to $WINSYSDIR$
Install Files $SOURCEPATH$\\File2.dll to $WINSYSDIR$
Install Files $SOURCEPATH$\\File3.dll to $WINSYSDIR$
...5)
How can I use the projects (and i'ts files) off-line on my laptop, after copying the files (back) to the laptop?
