Multi-language install, localized folder names possible?
Palle
Post by Palle »
If I make a multi-language install, is there any way that folders I need to create and put some files into (in the Documents folder) can have localized names (meaningful to the user)?
Yep, test the pre-defined variable $LANGUAGE$ in your MSIcode script and then create the folders/install the files as necessary.
