Is there a built-in way to set the application that I pack with the Installaware to run on startup (windows startup)?
I didn't find it on the IDE or in the plug-in list.
If not, what is the best way to do it?
Edo
Run Application on Startup
goje_sandeep
You can make that happen by scheduling a task to run at boot.But you the installer will need to be installed by admin or need admin rights to do it.
If you want to just start your application when the user logins then just add a short cut to your application in startup folder.You can get this by using Get Folder
