I'm using the InstallAware 9 Trial for now, but I think, I'm going to buy it, if I can solve this problem:
At first, I searched for this problem and found two other threads hereand here
I understand the logic that I have to set my "edit ini file" commands before the command "Apply Install"
At first, the script installs a file called "ro.ini" which holds per default:
As the setup and the installed application ships with five different languages, I want to set up the application's language to the one the user chose during the installprocess.Ro.ini wrote:[Units]
Power=0
Capacity=0
Temperatur=0
Volumenstrom=0
Länge=0
Masse=0
Druck=0
LA=0
Wassermenge=0
Druckverlust=0
[Options]
Language=0
Build=0
To do that, I wrote this script:
Install Files F:\\Dokumente\\Projekte\\Roller\\Installer\\Files\\Ro.ini to $TARGETDIR$
Comment: Ini-Datei mit der Sprachwahl schreiben
if Variable LANGUAGE Equals (Ignore Case) german
Edit INI File $TARGETDIR$\\Ro.ini, [Options] Language=0
else
if Variable LANGUAGE Equals (Ignore Case) english
Edit INI File $TARGETDIR$\\Ro.ini, [Options] Language=1
else
if Variable LANGUAGE Equals (Ignore Case) spanish
Edit INI File $TARGETDIR$\\Ro.ini, [Options] Language=2
else
if Variable LANGUAGE Equals (Ignore Case) Italian
Edit INI File $TARGETDIR$\\Ro.ini, [Options] Language=3
if Variable LANGUAGE Equals (Ignore Case) french
Edit INI File $TARGETDIR$\\Ro.ini, [Options] Language=4
else
Create Folder $TARGETDIR$\\db
Create Folder $TARGETDIR$\\drawings
Create Folder $TARGETDIR$\\forms
Create Folder $TARGETDIR$\\help
Create Folder $TARGETDIR$\\language
Create Folder $TARGETDIR$\\pictures
Can anyone help me with this problem?
I'm slowly getting crazy about this
