I've done a search, but cannot find if anyone has done a script to determine if the OS is Windows Server 2008 R2.
I need to exclude some runtimes to get my installer working properly in Windows Server 2008 R2. Any help would be appreciated.
=-Chris
How to determine if OS is Windows Server 2008 R2
Quick test...
Ok, as a quick test, I did the following in my main script:
Set Variable OSVersionR2 to
Get Exact OS Level into OSVersionR2
Write into Text File C:\\info.txt from Value $OSVersionR2$ (at end of file)
It reports back to me SEVEN (which is what I expect)
Then I tried this:
Get System Setting Windows 2008 into OSVersionR2
Write into Text File C:\\info.txt from value $OSVersionR2$ (at end of file)
The info.txt file reports this:
SEVEN
FALSE
Ok, So I know it is not Windows 7 CLIENT (as opposed to Windows 7 Server (which is What Windows 2008 R2 is)
I change the above to do this:
Get System Setting Windows 7 into OSVersionR2
Now I get:
SEVEN
TRUE
How do I tell the difference between Windows 7 CLIENT and Windows 2008 R2 SERVER?
The GetSystemSettings does not list R2 as an OS to select yet
=-Chris
Then I tried this:
SEVEN
FALSE
Now I get:
SEVEN
TRUE
=-Chris
I'd check for SEVEN, and then for server capability using Get System Setting Windows with Server Features into...
Tiago, please do not post the same question to three different topics - this is dangerously close to spamming and can get you banned.
Sorry for that, Michael and thanks for your answer in the other topic (http://www.installaware.com/forums/viewtopic.php?p=19484#19484). Perhaps it may provide a clue or insight to people who are trying to detect Windows Server 2008 R2 and other Windows sub-versions, too?
Thank you so very much!
Users browsing this forum: No registered users and 28 guests
