I'm new so take it easy on me...
Very simple, all I want to do is:
1.) install a file
2.) use runprogram to run an .exe that will modify the file
3.) then copy the modified file to other directories
I found out that cannot use the copy command since the copy action has to take place after the apply and apparently the copy command is no good after the apply.
Copy Local Files $TARGETDIR$\\abc\\somefile.txt to $TARGETDIR$\\123\\somefile.txt
How do I use CopyFileA to accomplish this?
This is what I've tried so far:
~InstallAware Clipboard Data~
~Call DLL Function~
~{B3D61ED3-3FE0-4A76-BE97-ED665707F1B7}~
~kernel32.dll,CopyFileA,bool,COPYISSUCCESS01,"pointer to string",$TARGETDIR$\\abc\\somefile.txt,"pointer to string",$TARGETDIR$\\123\\somefile.txt,bool,FALSE,$~
~mIDEFunc.dll\\mEXEFunc.dll~
CopyFileA help please
5aclockshadow
5aclockshadow
Thanks, I tried that but my install is very long and it installs all the files all over again.MichaelNesmith wrote:You can call Apply Install twice
Is it very difficult to use CopyFileA?
I have also played around with a batch file but it is ugly and I feel this simple action should be able to be accomplished easily from the installer.
Please help!
5aclockshadow
Yes, I believe so...I'm not sure the best way to do it or where to define it so I did it here:MichaelNesmith wrote:Is COPYISSUCCESS01 defined before making this call?
~Set Variable~
~{A0FC0509-D9EC-481A-9154-01D5B1FFE005}~
~COPYISSUCCESS$MYAH$MYAH$FALSE~
~Set Variable~
~{A212C872-9213-4630-9A0B-C423867F84E9}~
~COPYISSUCCESS01$MYAH$MYAH$FALSE~
~Comment~
~{FF3F89EF-7E2C-4400-812F-0961434789AA}~
~Created CopyIsSuccess variable so that the config files are copied towards the end of the script (used Apply Changes command)...not sure if this was needed or not - RMN VW07.13 Setup v02.00.01 1/15/10~
~Label~
~{7CE5BE9A-8012-43FE-8C0A-42B5F7F66C37}~
~Setup Type~
label: Setup Type
Comment: Created CopyIsSuccess variable so that the config files are copied towards the end of the script (used Apply Changes command)...not sure if this was needed or not - RMN VW07.13 Setup v02.00.01 1/15/10
Set Variable COPYISSUCCESS01 to
Set Variable COPYISSUCCESS to
Also, fyi ... I originally copied from here:
http://www.installaware.com/forums/viewtopic.php?t=1372
5aclockshadow
Changed bool=FALSE to bool=0 and it worked...it will now copy the file even if it already exists.
Here's the code:
~Call DLL Function~
~kernel32.dll,CopyFileA,bool,COPYISSUCCESS01,"pointer to string",$TARGETDIR$\\abc\\somefile.txt,"pointer to string",$TARGETDIR$\\123\\somefile.txt,bool,0,$~
In text format:
Call DLL Function kernel32.dll->CopyFileA (get result into variable COPYISSUCCESS01)
Thanks for the help.
Here's the code:
~Call DLL Function~
In text format:
